Will replace battery indicator will fix sleep sensor problem?
Hi everyone,
I just want to ask if the magnet test( put magnet to make Macbook sleep) not working, will it be the battery indicator/ sleep sensor cable faulty( my battery button indicator still work perfectly) . I just have the problem with Macbook does not enter sleep mode when i closed lit( have ruled all possible solfware issues). Any help would be appreciated.
Ist dies eine gute Frage?
2 Kommentare
Has the screen been worked on?
von mayer
Yes, it works perfectly, i believe that the issues is the sleep sensor since i has uses the magnet to test it. And the macbook does not sleep when i uses the magnet to fool it so i believe that the problem probably be the sleep sensor. I just don't know if replace it will solve the problem. Thank you for your participation
von harryha
