Zum Hauptinhalt wechseln
Released in 2010, the HP Deskjet 1055 is an all-in-one printer, scanner, and copier.
7 Fragen Alle anzeigen
I changed the ink but it won't print
I changed my ink both black and tri color but my HP Deskjet1055 Printer won't print
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare:
do you get an indication light ....error sign
von
Yes on my ipad
von
Einen Kommentar hinzufügen
3 Antworten
Hi Sharon, if your HP printer is still unable to print after recycling the Ink Cartridges, it's most possible due to improper alignment of it.
Try these steps:
Open HP print manager -->> Select setting and maintenance -->> Select align print cartridges
Now take out printed paper, you will see two dot lines parallel in red and black. Examine the alignment of the lines, click the numbers and letters for the best alignment, a dialogue box will appear to your screen, click continue, a new page will be print, now check whether these alignments are correctly printed on the paper, if you found irregularity over alignments, repeat this step 3 or 4 times to continue.
h/t: How to Set-up Print Cartridges to the HP Printers?
War diese Antwort hilfreich?
Bewertung 0
i changed the ink and now the printer isn't working right
Bewertung 0
إمبارح عملت نعم بل فعل
Bewertung 0
Antwort hinzufügen
Sharon Laughlin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 8,383
