*#06# won't show imei
when i type *#06# won't show imei
but when i go to settings/about imei is there
i have no service
Ist dies eine gute Frage?
i have no service
Check your modem firmware. Go to settings,general and about and check if there are numbers there,if no numbers it means firmware is corrupted. First restore your phone and if still problem not solved then you go the hardware way. You'd have to change your base band chip which is a bit difficult.
War diese Antwort hilfreich?
it's not firmware issue it's hardware
I think the baseband needs to be reballed, this is a common issue. During update or restore do you get error -1? If you do then it definently needs to be reballed.
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 3,867
i need a answer for this question too . i have more then 5 iphones same issue
von r.o0y
do you do microsoldering
von Adrian Zymeri
Pls help me with my iPhone 6 plus Didn't show IMEI number
von Oluwaloniglory
