Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Das Samsung Galaxy S4, Modell i9505, ist mit einer 13 Megapixel Rückkamera und einem 5 Zoll 1080p Display ausgestattet.
648 Fragen Alle anzeigen
Galaxy s4 camera fail
When I use the camera app it shows just a black screen and it says camera failed. Also I tried using a third party camera app and the front camera worked but the rear had green lines running across the screen. I went online and tried everything software wise to get it back to normal. I wiped the cache Portion and did a factory reset but still the same thing happened. Then I bought a new rear camera and still nothing. When I opened the third party camera the screen was black for the rear but worked in the front. Any other ideas?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Could it be possible that the phone was in contact with water? Did you try cleaning the connector before reassembling the new camera part? Have you tried flashing another firmware?
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
It may be possible I bought it from someone I know and I doubt it had had water damage. I don't think I did clean the connectors how should I try? And how do I flash another firmware
von
Antwort hinzufügen
Gabriel Huerta wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 77
