Hi David,
If your charging cable will charge other devices, but not your Eee Pad, it's likely that your device itself is damaged. As you mentioned in the question, the charger was pulled out harshly, which can often damage the cable or the charging port on your device.
First, I would power down your device and take a look at the charging port. Clear debris out of the port if you see any; sometimes a small piece of plastic could break off and interfere with the connection. If that doesn't help, and if the port appears bent, you can attempt to bend it back into place (if this doesn't work, your port is probably broken, so there is no risk in trying to fix it).
If neither of these solutions work, you will probably need to replace the charging port on your device.
You can also check out more solutions to this issue on the Eee Pad Transformer Prime Troubleshooting Guide.
There isn't a repair guide that I've found on IFixit, but the page has the "student working on this page" flag, so there will probably be a guide posted soon.
Hope this helps!
Aaron
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
