Zum Hauptinhalt wechseln
Repair guides and information for knife sharpeners.
Where do I get replacement stones for the Chef's Choice 120?
Update (10/29/2016)
I'm not getting a lasting edge anymore. I spent some time with a machete on the sharpener and may have damaged it.
Chris
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
5 Kommentare
I have a 300 and a blade come loose and fell out. Question: how do I open the unit without all falling out? I tried placinthe blade in, but was unsuccessful due to the magnetic pull.
von
had the same problem with mine, turned it upside down, took the screws out, removed 2 bolts that hold hone assembly to motor, had to use a razor knife between magnet and blade, once I got it loose was able to super glue it back in place, mine's an old one, had it since 2004, can't find good info for replacement parts
von
I just had the same problem with my 300. I did the same thing as the 2nd commenter did (including the super glue) but one of my coarse hones is missing. This seems to be a common problem with this model.
I sometimes see these sharpeners at thrift stores. I guess next time I'll buy one for backup parts as the Chef's Choice site doesn't offer them as replacement parts.
von
I had the same exact situation as you. They told me that they discontinued replacing of the stones when Covid started. And suggested I buy a new one and these are not inexpensive. They offered me like a 25% off or something I just was so disappointed.
They also suggested going on eBay to see if I could get any of the parts and try to do it myself. Chef's choice does not replace the stones themselves. It was another company and I don't remember the name but researching I did find them but they would not service
directly and they wouldn't help.
von
Great to know other people have the same problem as I but whom can I connect with to have a solution. Re a person that can repair my chefchoice model 120
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hi,
This is what the EdgeCraft corporation (makers of your sharpener) have to say about replacement stones.
Used in a household setting, the abrasives will last for many, many years without need for repair or replacement. If the abrasives need replacement, you may send the sharpener back to EdgeCraft and, for a nominal fee, EdgeCraft will replace the abrasives, clean and lubricate the sharpener and ship it back in almost new condition. The abrasives, however, should last a very long time with normal household use.
Here is their contact details
CUSTOMER SERVICE
1-800-342-3255
Hopefully this is of some help.
War diese Antwort hilfreich?
Bewertung 6
6 Kommentare:
I did the same thing and I can see that stage 2and 3 are now putting more edge on the right side of my knives and not very much on the left and leaving me with very dull knives
von
so what did you do about it ?
von
I have sent these units into Edge Craft for repair and gotten them back in like new condition. At the time it was 45 dollars and you ship it to them via UPS or Fedex.
von
Repair service no longer available. EdgeCraft will offer a 15% discount, from full list price on a new unit, but units are no longer serviceable and no spare parts are available
von
Dull units are now scrap, choose a different system with replaceable abrasives
von
1 weiteren Kommentar anzeigen
I returned my Model 120 to Edge Craft for them to replace the sharpening discs many years ago and it was well worth it. Now it’s time to send the machine back again. The factory says “the discs last for many years”, and they do, but it HAS BEEN many years, so it’s time to do it again. I even opened mine up to see if the 2100 model disc set would fit, and IT WON’T, so don’t waste your time trying. In the Model 120, the shaft that the discs are on is integral with the motor and can’t be removed without disassembling the entire sharpener. But on the 2100, there is a rubber shock coupling that connects the disc shaft with the motor shaft, so a new disc module can be installed easily, but that feature is absent on the Model 120. Maybe they should put a placard on the Model 120 that says “No user serviceable parts inside”, because that is truly the case. Bite the bullet and send yours back to the factory, just like I’m going to do for the second time.
Bewertung 3
9 Kommentare:
As of 5/26/2022, here is the response I received on a reconditioning enquiry;
Hi, this is Noe from The Legacy Companies. Thanks for reaching out. I'm sorry if you've experienced this. But I'll be glad to help. Since the pandemic started we no longer have repair center anymore. If your machine is still under warranty we can file a warranty replacement of your unit if this is not functioning well anymore. Just provide the photo of the sticker label a the bottom of the unit and a proof of purchase.
So it looks like no more reconditioning service.
von
This company sucks. They have ZERO customer loyalty. Saying that they dont sell parts for a sharpener that cost around $150.00 is absurd. Grinding wheels are aa wear item on ANY type of grinding operation. I can only hope they go under as a result of their !#^& poor customer service. I would customers to return this item to the store they got it from. Do not waste your money. The fact that america's test kitchen reviewed this product and gave it high marks makes me think that sponsors are buying answers on that show.
von
I agree with Jim. I purchased this sharpener because of the glowing review that America's Test Kitchen gave it. If I wanted a use till broken machine I would've shopped at Horrible Freight. There's no excuse for not having spare parts available on pricey appliances that are still being sold. Stay away from this company.
von
The company really sucks. Once you buy their product, unless your credit card company refunds you, there is no recourse to get any service a year from purchase date. They simply discontinue their model, and you are up the creek without a paddle. Mine hardly sharpens anymore though it runs perfectly. So, my option now is to send it to the landfill. I will never buy their product ever. $150 for three years of few sharpening is a lot of money down the drain. Sam in Ohio
von
Full agreement!
Enough money spent, there should be replacement grinding disc available.
The company offered me 15% off a new device. Why the hell would I buy something else from them when it’s non-serviceable. Very disappointed! Vote with your dollar people!
von
4 weitere Kommentare anzeigen
I'v had this Model 110 for 20years! Has never disappointed me! After reading these comments I fear that I should not return this model for service. Does anyone agree with this or should I reconsider?
Bewertung 1
2 Kommentare:
Hi @sharpener,
Chances are you won't be able to get it fixed as the manufacturer doesn't even list your model in their parts list and with some other models not all the parts are currently available.
You could always contact them on their Chat line (link in parts list) and check what they say about parts for your model.
Just my view.
von
And I was going to ask about my model 100.............
von
Antwort hinzufügen
plumbnut wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 37
Letzte 30 Tage: 177
Insgesamt: 30,048
