What format should I use to run mac os x?
there is two types of format, Fat 32 and NTFS, which one should i use? what i did is to make a disk partition.
Ist dies eine gute Frage?
both FAT32 and NTFS are for originally windows based machines. Mac can address both kinds but not "run" from them.
To run Mac OS you need an HFS+ partition. (probably also need a swap partition, usually Mac OS does all this for you, this guess of mine is based on how Linux systems are setup).
If running more then one OS on a dell with MAC OS can be tricky, only 4 primary disc partitions can be created. (at least with my linux and windows experience).
To format to HFS+ see the program listed in your other question. Simply creating an HFS+ partition may not be enough.....
War diese Antwort hilfreich?
Good answer Brian. What he is trying to do is make a Hackintosh and does not appear to be willing to do the study required. + for your answer.
Format it to FAT32, then boot it from the install disk, and reformat to HFS+ (Mac OS X extended). Mac OS X cannot r/w NTFS, but it can r/w FAT.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,066
