Zum Hauptinhalt wechseln
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
50 Fragen Alle anzeigen
Why is my timing chain loose?
I got valve cover off passenger side head and was checking out the timing chain and it was tight. Then turned crank to where timing chain moved about 2" and checked it again. It was loose. Is this normal or do I need to fix something?
2000 expedition 5.4l
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
@weelee why did you check the timing chain? What are the issues with your Ford? Anything related to the timing going on? How many miles are on your engine?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@weelee , Lee, sounds like you have an issue, could be stretched chain, worn/broken guides, worn timing gears but the biggest issue here is probably a faulty timing chain tensioner, could be a combination of wear on all timing chain components.
Since this is what is known as a interference fit engine, it is best to change all the components and the timing chain and be sure to use the Ford recommended oil in your 5.4L. Check the attached video links, showing tear down, timing component wear and failure. Good luck.
https://www.youtube.com/watch?v=zkzsnie4...
https://www.youtube.com/watch?v=aUBx0RXj...
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
lee fletcher wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 2,528
