do I need new battery
Flashes amazon when unpluged works when pluged in.
Ist dies eine gute Frage?
If you bought the phone two years go and have used it frequently I think you might need a new battery since I have switched battery fro most of my phone between year one and two.
Update 13.9.2017:
You will need a battery like this
https://d3nevzfk7ii3be.cloudfront.net/ig...
from the ifixit guide.
Amazon Fire Phone Akku ersetzen
Search for the PN number on any sales site like e.g. ebay
War diese Antwort hilfreich?
But when phone is plugged in it shows the battery charging ok
So I don't think I have a battery problem
Hi @ashanti_barrett ,
Just because the battery shows that it is charging doesn't mean that it will hold its' charge when charging is complete.
All batteries have a life span, including rechargeables. If it works OK with the charger connected but not when on the battery alone the most likely problem is the battery.
An example is that when on the battery only, if it is failing it might not be able to supply the correct voltage level, when under load, that the electronics require to work properly, whereas a charger will always supply the correct voltage, regardless of the load placed on it, (within reason of course).
The easiest way to prove this is to change the battery. If the new one works, problem solved, if it doesn't then you have to delve further into the problem.
hi , i think i have same problem. what kind of battery needed, do you know?
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 277
