After successfully replacing the digitizer, the LCD won't turn on
After a digitizer replacing process worthy of Dante's fifth circle of you-know-what, I reassembled my iPad 3, and successfully turned it on. I swiped to turn it off once again before sealing it back up. However, just a couple minutes later, after using the blow dryer to seal the edges, the iPad failed to turn on. Or at least, there is no indication that the device is on. Nothing shows up on the LCD. I tried the following, without success:
- Restoring the iPad via iTunes. iTunes still recognizes the device, but restoring didn't fix the problem.
- Pressing and holding the power button for at least a minute.
- Pressing and holding the power button and the home button simultaneously for at least a minute.
- Disassembling it again and checking that the LCD ribbon cable is pushed adequately into its port, which it is.
- Disassembling it again and detaching the logic board from the battery for about thirty minutes, then reassembling it.
The battery life does not seem to be the issue, as it is at least halfway charged, as indicated by its presence in iTunes, and I've also tried resetting after the device is plugged in to power.
I am just about at my wits' end. I mean, it was working after I replaced the digitizer. I changed nothing between testing it out, and folding it up to start sealing it.
I don't know if I should start saving for a new one, or try replacing the LCD itself. Of course, I don't know if that would even fix the problem.
HALP!
Ist dies eine gute Frage?
