Zum Hauptinhalt wechseln
The second generation (KK) Jeep Liberty, a compact 4-door SUV that restored the classic sharp lines of the original Jeep styling.
19 Fragen Alle anzeigen
heater blowing cold air
2008 Jeep Liberty
ac working good. heater blowing cold air. coolant level is good. temperature gauge in good level. floorboard not wet like other autos I've had that had bad heater core.
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
I would take a look at the actuator. Here's a very good answer on this with diagram on it:
http://www.justanswer.com/jeep/7fdvs-lib...
War diese Antwort hilfreich?
Bewertung 4
Take the two hoses near the fire wall to the heater core off and flush it out, make sure to flush out in reverse, so as not to push obstruction further into the heater core.
Take a water hose and flush it out till clear of obstruction
Bewertung 1
Most likely be the resistor behind the glovebox. Very common issue
Bewertung 0
Antwort hinzufügen
kathy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 88
Letzte 30 Tage: 284
Insgesamt: 34,718
