My phone is turned on but the screen is frozen
how do i unfreeze my mobile phone
Ist dies eine gute Frage?
I've had my Alcatel OneTouch for a few months and just had the same issue.
Hold volume down + power for about 5 seconds, this restarted the phone. Release buttons when the Alcatel logo appears.
It's working great now!
War diese Antwort hilfreich?
this did not work!
This did not work for me. I had to take the battery out and put it back in. Then turn the phone on again and this worked.
my screen is frozen i can i fix it
just held the button and it just came back on
I have the same problem. The screen was freeze and I can not swipe, I can not unlock. I already turn it off &'on several times but it does not work. I also remove the sim & SD card but still it is not working. Please help.
Try things in this order.
1. Try a normal off/on (hold red button until powers off, wait a few seconds,
turn it back on). If it won’t power off go to #2.
2. Hold red button AND volume down until it powers off, wait a few seconds,
turn it back on). If it doesn’t power off, go to #3..
3. remove back cover, remove and re-insert battery, replace cover, power on.
should not require removing Sim and/or SD card(s)
Good Luck
Oh my God it worked!!! thankssssss
What if your battery doesn't come out?
None of this worked for my Alcatel Lumos, and I can't take the battery out.
My advice is trust that Paul Cooper guy!!!!
My boyfriend called me, and it just unfroze….
You should hold your power button for about seconds are until the logo shows up once the logo shows up let go of the button and now you don’t want the same thing to happen so what I like to do is I like to give the phone about 15-20 seconds to completely get everything back straight but sometimes you have to make sure that you don’t have too many things open on your phone at once because sometimes that can also be the cost of your phone freezing give it a break sometimes
My alcatel 7 one touch won't even turn on. I tried holding the volume down button and power button, didn't work. I tried plugging it in and didn't work. My phone's battery does not come out. I tried allot of YouTube videos, didn't work.
Help please.
If your phone is an Acatel One Touch flip phone Your battery will come out. Use you thumb nail to pry off the back. There's a really thin seem along the edge, your nail can get in and it should come off easy. Then just pull down on the top of the battery. Pull the battery out, then put it back in. Then turn you phone on as usual, by holding down the on/off button for a few seconds, then allow the phone to start.
Alcatel Lumos won't shut off or recognize touch on screen, can't take battery out at all, any suggestions? I've tried all button combinations and can only screenshot.
Letzte 24 Stunden: 12
Letzte 7 Tage: 41
Letzte 30 Tage: 197
Insgesamt: 27,183
8 Kommentare
i am having the same problem!!!
von Jennifer Fonseca
bla bla bla bla this and than bla my phone is frozen and it been on the same screen for 2 days
von shannoncunningham1
Yep, same issue. Mine won't turn on or off. Just stuck on Google play. Tried swiping, nope doesn't work. Tried to even factory reset, nope didn't work. Plugged in, nope nothing…. Tried everything YouTube through at me too. Nothing. Any suggestions??
von Angela Brooks
Mine is frozen but it can turn on and of but I can't remember the
von Adara Moise
I got off from talking to a friend and my phone shut off and wouldn't turn back on so I took the battery out for it to reboot. What's that all about ?
von rg1
3 weitere Kommentare anzeigen
