Zum Hauptinhalt wechseln
The HP Compaq 2510p, model number "GM651AW" and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
4 Fragen Alle anzeigen
My laptop won't power on.
I press my power button, and my computer wont turn on. There's no lights when the battery is plugged in either. Does anyone know whats wrong?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Student question
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
You can try doing a static discharge . Remove the battery and unplug the laptop so there is no power to it at all . Then hold the power button down for 60 seconds this drains any residual power from the memory and allows a clean boot. Then reconnect the battery and power and boot the computer normally. If this gives no Joy test your power adapter to see if there is an issue there .If the adapters not providing power it wont charge the battery Hope this helps
War diese Antwort hilfreich?
Bewertung 4
Your battery may be defective. However try removing the battery for 60 seconds and see if the problem persists.
Bewertung 0
Antwort hinzufügen
Dan Champagne wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 2,454
