Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Touch Screen sometimes doesnt work
Hello Peeps,
this is my first post soooo.
Well let me explain the problem here. I bought an iPhone with screen defective i changed the screen and noticed that the touch doesnt work always. Means
I have to lock and unlock again again till it start working but then it stops and i have to do the proccess again. I bought another screen and replaced it again but the same problem stills. When the iPhone gets warm then the touch screen "okay".
Just to know I'm ready to resolder something because im a Microsolder :D
Edit: It is an Orginal Apple Screen from an Working iPhone 5
Best Regards From Germany
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
This is a common problem with bad quality copy screens
It is believed that the static from swiping the phone causes the problem and locking/unlocking resets it
War diese Antwort hilfreich?
Bewertung 0
6 Kommentare:
Yeah but it was a Apple Screen from an working iPhone 5 :/
von
Oh, not sure then
von
Check the digitizer (touch screen connector) on the board for any liquid damage.
Remove the black plastic tape cover thingy that is around the front screen connectors on the logic board to allow looking at the components near those connectors for any corrosion or liquid damage. If you do find liquid damage use 95%+ isopropyl alcohol to remove / clean them. I usually use like a clean toothbrush or some brush to brush the corrosion off / clean the board.
corrosion or liquid residue.
von
I removed it but the problem stills.....
von
You removed the liquid damage?
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Mark Muster wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 342
