Zum Hauptinhalt wechseln
My tablet can't pwer on
I have problem about huawei tablet
it's can't power on.
I checked the connector and the battery, no problem
what is the problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 21
14 Kommentare
where to buy an extra board power ic ?
von
it's can't read the puce
von
My Huawei t7 cannot power on. I have also press the reset button (volume up+power), but it's not responding. Can I solve it with PC?
von
my huawei t3 7 can power on but the screen is blank what should i do?
von
It ask me for a code.
von
9 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@mohamedeln , med, Found this info. from searching through forums with similar issue as your huawei tablet t1. Hard reset. Take your sim card and memory card from the tab before the reset, battery is fully charged. Personal data from the tab, contacts, pictures, messages, apps. etc., will be deleted if it was not backed up.
Press and hold volume down key and power key for a while, your screen should turn on with option to enter recovery, follow the prompts to enter recovery mode and set the device to factory defaults. Check the link below for tutoral on reset. Good luck.
https://www.youtube.com/watch?v=7zbLOEN0...
War diese Antwort hilfreich?
Bewertung 14
8 Kommentare:
My phone doesn't have any network
von
My tablet says that it still needs more charging, even though it doesnt
von
How am I supposed to hard reset it if my screen is still black
von
my photos are not saved in sd card they are saved in tablet, i don't want to delete those
von
i try all of the ways but nothing works please help me
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
med wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 52
Insgesamt: 46,423
