Zum Hauptinhalt wechseln
Soldering 9 wires in wireles headphones
Hi,
I bought Powerbeats 2 that as turned out have damaged cable. I opened them, desolder all the wire and I'm left with 9 of these.
How should I connect them?
CABLE/WIRES - https://postimg.org/image/9gzv7i5jb/
BATTERY - https://postimg.org/image/zdtjk496v/
BATTERY (connected after opening) - https://postimg.org/image/5zxt4j6h3/
HEADPHONE - https://postimg.org/image/qlh6a6dfr/
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Here are the original wire locations:
Battery 1
Battery 2
Main Board 1
Main Board 2
Main Board 3
Volume Board 1
Volume Board 2
Volume Board 3
Volume Board 4
War diese Antwort hilfreich?
Bewertung 6
3 Kommentare:
Where's the main circuit board that the mic and volume controls are on that have the I wanna say 5 but possibly 6 different wires soldered to it!???
von
sorry for the delay Clint here is the image. the wire between the blue and yellow is black if you can't tell in the image. It appears to only be 5 wires soldered, the 6th solder pad appears to be unused.
von
Thank you so much, never would've gotten this soldered correctly without those, you're a life saver!
von
Thanks you so much.
But could you please help me to let me know the Cable in Right Speaker (while and red-green) connect with what color in the long cable.
Thanks you so much guys.
Bewertung 1
3 Kommentare:
I posted the answer to this I believe right above, please take a look...thanks
von
Hello sir, i have same problem with clint. I soldered the 3 wires in battery and it works.. But there are 3 more wires. The yellowred, the black, and the greenred..How do i connect for the right earbuds. Hope you're immediate response..
von
If this was for me, sorry for the delay...please post against my answer and you will get a quicker reply. Again the images are all above for every wire in the system
von
Antwort hinzufügen
Tomek Dorobisz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 6,675
