Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und seit dem 19. September 2014 auf dem Markt.
4564 Fragen Alle anzeigen
Parts of screen do not work after battery replacement.
After a battery replacement I noticed the following:
1.1)The y or 6 key is not working. I tried the phone on landscape orientation and I saw that the keys were working. Then I tried to draw something on an app, and I saw that in the same place I coudn't draw. As you can see in the following images
the touch is not working in this specific area, (like a vertical line).
1.2)The other thing I noticed is that in this area, some times there are two white lines. They are not there all the times, they appera and dissapear.
The first two are the main issues, and what bothers me more.
2.1)Some times the touch screen when I swipe on one side and want to change screen, doesn't go to the next screen, but to the screen after the next. (Eg let say I am in the main screen and want to go the secong on the right, it could go directly on the third)
2.2)In addition to the previous, sometimes, when I swipe, instead of swiping ,the phone functions like taping, and it enters an app.
Those two are not so important, but I add them just in case, to find out what is the main issue.
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Erfolgreich repariert? Genial!
Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
Wir sind alle Genies
1 Antwort
Gewählte Lösung
Hello George, first thing I would try is disconnect and reconnect the cable connections for the screen. But before you disconnect the screen, make sure you disconnect the battery first because if you leave the battery connected while disconnecting the screen you risk damaging the screen. After that do a soft reset.
War diese Antwort hilfreich?
Punktzahl 1
Kommentare:
Hello Lay! Thank you very much, I will give it a shot!
von
Antwort hinzufügen
George Drg wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 35
