Zum Hauptinhalt wechseln
Die Nikon 1 AW 1 ist eine wasserdichte Kamera aus dem Jahr 2013. Diese Kamera ist WLAN-fähig und zeichnet mit einem 14,2-MP-Objektiv in 1080p auf.
Why doesn't it connect to wifi anymore?
I was using my Nikon 1 AW 1 the other day and I had no problems connecting it my home wifi. However, today I go to use my camera and now it won't connect. Is there anyway I can fix that or do I need to replace the camera completely?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Great question! Firstly, make sure you turn the camera on and off to see if that helps. If not, make sure the settings are set to allow wifi connectivity. If neither option helps, then you can certainly repair that without having to replace the whole camera, though it will take a little work. If you replace the motherboard then the wifi components (drivers/hardware) will be replaced with it. You'll only need to buy another motherboard for the Nikon 1 AW 1. Here is a detailed guide on how to do it yourself!
Nikon 1 AW 1 Motherboard austauschen
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Joshua Bohorquez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 21
Letzte 30 Tage: 28
Insgesamt: 442
