Zum Hauptinhalt wechseln
Model M8407 / 550 or 667 MHz G4 processor
28 Fragen Alle anzeigen
How do you fix the Clock reset problem?
I need to reset the clock after each power-down.
I am sure I need a pram battery, just not sure which one:
The 3v lith coin cell, or the:
The G4 Titanium Mercury PRAM Battery @ $39.95
Product code: IF121-017-1
Apple Part #: 922-436
Do I need to open up the case to see which one?
Thank you.
DC
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Your PRAM battery needs to be replaced. It appears to be part number 922-5205 for the PB G4/DVI 667. Here's Apple's guide on which battery you need: http://support.apple.com/kb/ht2295
War diese Antwort hilfreich?
Bewertung 2
You must know
the exact specifications of your PowerBook.
PowerBook G4 (15-inch FW800) & PowerBook G4 (15-inch 1.5/1.33GHz) 922-6007
PowerBook G4 (15-inch 1.67/1.5GHz) 922-6714
Powerbook G4 (15-inch Double-Layer SD) 922-7173
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Bewertung 1
Antwort hinzufügen
Crocdog wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,725
