Zum Hauptinhalt wechseln
adhesive won't stick on new cable
I bought new volume cable but can't get the adhesive to stick. Any Advice?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Replace the existing adhesive on the housing or volume button cable itself with new adhesive?
I know that Tesa / Red transparent double sided tape works well for this.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
It kind of depends on what part of the cable. For most of it, red tape is fine. The part that always gives me problems is where it goes from volume to power and is on top of the frame. I use yellow tape for that part. If the volume buttons are giving you trouble, cut out tiny little pieces of red tape.
I'm pretty sure all of those volume flexes were made when Reagan was in office. The adhesive is always messed up on them when I go to use them.
War diese Antwort hilfreich?
Bewertung 2
Yes the tesa tape would work with this repair.
Bewertung 0
Antwort hinzufügen
Brandon Ballington wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 8
Insgesamt: 111
