Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2686 Fragen Alle anzeigen
Touch ID fails, double tap works
Hi everyone!
After I replaced the screen (screen only) on my iPhone 6S, the Touch ID fails - even though the double tap for one-handed mode works.
I already transfered the small conductive plate beneath the connector (like described in Touch ID not working after screen replacement?) and took everything apart and reassemled it plus did a factory reset and disconnected the battery.
I was very gently while transferring the home button to the new screen - there is absolutely no optical damage.
What would be the next, you would try?
Could it be a problem, that I used the phone for testing purposes with another display and home button for some time?
Thanks for your help in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
The chances are the home button extension cable may be faulty on the replacement iPhone 6s screen, every screen comes with it assembled together.
von
Well, that's worth a try! I'll check it with the old broken display tonight. Thanks :)
von
Didn't work with another screen. Either the Touch ID IC is broken or ... :-(
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I had a very similar situation with a iPhone 6, no Touch ID after doing a screen replacement. Checked everything and nothing was damaged, tried a another screen had the same results. The next time the customer did a IOS update it started working?!!
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Yeah I had an issue like this on iPhone 5s. The customer didnt come back so I assumed the touch ID not working fixed itself.
von
Must have been a lucky constellation, so that apple seems to have changed something with the authentication. I'll wait for an update definitely. :D
von
WHAT THE HECK :o
It just started working out of the nowhere :D
Think I had a problem with my magic wand or so...
von
Antwort hinzufügen
Sebastian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,965
