Zum Hauptinhalt wechseln
Released May 1, 2012. The first backlit eReader tablet emits a soft backlight for improved night reading. The device is simple to open up, but the components are all connected.
33 Fragen Alle anzeigen
The connector is not working and I cannot sync nook to compute
I like to rent books on my nook and require a usb connection with my computer. When I try to connect, the cord is loose at the mini-usb port on the nook. This results in a transient connection and the nook cannot be recognized by the computer. How can I repair this?
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Here is a link to a video which shows how to replace the battery in your device. I realize that this is not your problem but the video is useful as it shows how to open your device so as to gain access to the systemboard.
You only have to watch the first 2:15 minutes of the video as the systemboard is accessible by then.
https://www.youtube.com/watch?v=fDqzJWHE...
The charging port is mounted on the systemboard and most likely has become dislodged causing your problem.
You will need surface mount soldering skills and tools if you wish to repair the connection or to replace the charging port. if you have to do this instead
If this seems too daunting then I suggest that you take it to a reputable, professional computer or mobile phone repair service, who give a guarantee on their work (even if it is only for 30 days), and ask for a quote to do the work.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Jennifer Connors wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 393
