Hi,
What is the model number of your Vaio laptop?
Try the following:
Remove the charger, then remove the battery pack from the laptop.
Press and hold the Power button for 30 seconds then release the button.
Connect the charger to the laptop and switch on the charger. (leave the battery out of the laptop at this stage).
Start the laptop.
If the laptop starts, allow it to boot all the way to the Windows desktop.
When the laptop has 'settled' down, (i.e HDD light is not continually on) shutdown the laptop in the normal way.
When the laptop has completely shutdown, switch off and remove the charger from the laptop.
Re insert the battery into the laptop, reconnect and switch on the charger and start the laptop.
If the laptop starts allow it to boot all the way to the Windows desktop. Once there check the charge state of the battery. If it is charging allow it to fully charge before switching off the charger and removing the charger from the laptop.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
11
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
18 Kommentare
Hi , I put my laptop Sony VAIO in charge and when I came to turn it on , it’s not getting on , plz help me the model number is vpcsb31fx
von Zainab
I have a similar problem, I haven’t used my Laptop for a month or so did you ever solve on how to power it on?
von Stephannie Espina
No, sorry I didn’t, I just ended up buying a new laptop.
von kdcao1
I'm having the same issue maybe there is a way to get around the power button like a hacked version like u can do on desktops.
von Daniel Loper
Hi my laptop was also from Sony viao model SVT . At first i can switch it on as usual and doing my assignment and then the battery is running out so i charged it. Then after a while i tried to switch it on and it doesnt work. Can someone help me im a student so i really need my laptop back so that i can work on my assignments
von aliatrbl
13 weitere Kommentare anzeigen
