iPhone 5 no power after water damage
Now before you jump to the obvious conclusion, i have done a bit of troubleshooting. I followed the guide to repairing water damage and successfully removed all of the corrosion. I also followed the advice from the guide to replace the battery. Upon plugging into my mac itunes says it is in recovery mode. it does not respond to charging but i know the lightning connector works because it made the connection to itunes. I'm thinking that my next area to look at is the lcd/digitizer. Does anyone have any advice for troubleshooting this and maybe any tips for troubleshooting the screen? thanks guys!
Update (11/30/2016)
UPDATE:
I decided to have a look at the digitizer assembly and saw that it had evidence of severe water penetration. I tried swabbing the front and rear sides of the digitizer with isopropyl alcohol but there is still evidence of damage. Does anyone have any advice on removing said water damage/testing the digitizer? Or should I just replace the whole assembly?
Ist dies eine gute Frage?
2 Kommentare
Based on what you have written, I would focus on the "not charging" problem first. Until that works, not much point spending time on the screen.
Your profile shows you repair phones, so have you tried a known-good screen on the device? That would tell you all you need to know about the condition of the logic board. Once the board works, then you can determine if the screen assembly is fully functional or not and wether it is worthwhile repairing or replacing.
von Minho
Minho: I plan on trying that but I want to learn the more diagnostic as I am a novice repairman..I just don't want to throw parts at it and hope it works
von Tanner Haller
