Push bar to open door isn't working correctly.
When we push the rectangular area to open the door, it will still open, but feels loose. I'm afraid the latch will quit working entirely. It seems to be a spring that has maybe come off a bracket that hold it in place, or maybe the spring itself has broken. All the remedies I see, deal with a door latch that has a handle, this one does not have a handle.
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Kommentare:
Thank you very much for the diagram. It has pretty much confirmed that I have diagnosed the problem. Now, to decide if it is worth it to get it repaired! Or, perhaps the remaining spring will keep working for awhile!
von
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Antwort
Gewählte Lösung
Loise, Micro waves are one of the most (((dangerous))) appliances to work on! From the link below (parts break down) it looks like the release has 4 parts to it, the button, 2 springs,and lever. It looks like the control panel will have to be removed to see if the springs popped out of place to fix your issue. Best to have a good appliance tech, diagnose, estimate, make the repair as microwaves can be very dangerous to work on and should not be repaired by the inexperienced. Good luck.
http://www.partselect.ca/ModelSections.a...
War diese Antwort hilfreich?
Punktzahl 2
Antwort hinzufügen
Lois Fate wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 43
