Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
5058 Fragen Alle anzeigen
Camera not working after screen replacement
Just after replacing the screen on my iPhone 6 I noticed how both the flash and video camera work perfectly, even the panoramic view has no problem but the camera does not work. The camera app doesn't show the screen because its all blurry. What did I do wrong and how can I fix it?.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
You may have accidentally disconnected the back camera while replacing your screen. A more common issue is, your front camera flex could've been damaged in the repair process. If the front camera goes out, it could cause issues with the back camera.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
How could I fix this issue?, im not really sure about that because I can still record but no pictures.
von
i'm also going through a similar issue, my iphone seems to be seriously shoerted or something, It's draining up the battery and for some reason both the cameras and flash aren't working.
von
Antwort hinzufügen
Marcelo Marquez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 2,440
