Zum Hauptinhalt wechseln
Eine TV Spielkonsole von Sony Entertainment, auch bekannt als PS4. Sie wurde am 20. Februar 2013 angekündigt und kam am 15. November 2013 auf den Markt.
1697 Fragen Alle anzeigen
Kicks off Automatically and won't turn on
PS4 less than 1 year old. Can't find the receipt to take back for warranty. Basically used for Netflix and Hulu. Has no water damage or never been dropped. It has started kicking off automatically for. Now when I turn it on the blue light comes on it beeps and turns back off again. I heard it's a hard drive failure. Is it? Or do I need to trash it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This is a pretty common problem with these. It's not he hard drive. It could be the power supply but it's more likely that it's faulty solder joints under the APU. Here's my video explaining it more
Hope this helps.
War diese Antwort hilfreich?
Bewertung 1
6 Kommentare:
That's the exact same thing mine is doing. Sometimes it will come on and stay on for quite a while then it will kick off..
von
This is a super common problem so there are lots of people who are having the same types of issues.
von
I wonder if the bad solder joints issue under the APU can be fixed using a reflow machine which I do have.
von
Sometimes a reflow machine can fix it, but most of the time this problem is caused by oxidized pads on the chip so you would have to physically scrape the oxidization off in order for the new solder balls to stick.
von
What's the name of the part that I need to fix it and where can I get the part at?
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Shawna wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 56
