Wont shift out of first gear
98 dodge dakota 4x4 v6 3.9 Wont shift out of first and the trans temp light comes on
Ist dies eine gute Frage?
Either the fluid is very low, or fluid is not being pumped through the transmission.
Start out first by checking the transmission fluid while the truck is at operating temperature. If the transmission oil is low, check under the truck for any signs of leaks. If it's leaking from the transmission pan, transmission lines, or at the radiator... it's usually an easy fix.
If your transmission fluid is ok or low without signs of leaks, have it towed to a transmission shop. Don't drive it or you may risk more damage.
War diese Antwort hilfreich?
Letzten 24 Stunden: 0
Letzten 7 Tage: 7
Letzten 30 Tage: 20
Insgesamt: 1,341
