Zum Hauptinhalt wechseln
How do I disassemble the Kwikset Key-In Knob Locket?
I've tried to disassemble it but the cylinder thingy is frozen. It seems to be frozen in the locked position, even though I've used both the key and the thumb lock to try and unlock it.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
lauraevalentine , If this lock set is still installed on door, through the key slot, liberally squirt penetrating oil/ WD40 with a small injecting straw/nozzle and insert key in and out/wiggling and repeat several times till lock set works. Below find links for door knob removal and link from kwikset trouble shooting etc. Good luck.
https://www.youtube.com/watch?v=vESDjMTc...
https://www.youtube.com/watch?v=eigYEYR0...
http://www.kwikset.com/customer-support/...
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
lauraevalentine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 2,513
