Zum Hauptinhalt wechseln
Der Nintendo DS Lite kam 2006 als Nachfolger des Nintendo DS auf den Markt. Er ist leicht zu öffnen und leicht zu reparieren.
314 Fragen Alle anzeigen
Pitch Black Screens on my DS Lite: Solid Green Light Remains
In the past year, I began to revisit my DS Lite. I had not used in over four years and it failed to turn on at first. However, I temporarily fixed the problem by hitting the DS again the butt of my palm. The problem reappeared and I realized that if it pressed hard on the bottom left corner of the screen the DS would freeze. The problem continued to occur but I solved it each time by hitting the bottom of the DS under that corner of the screen. Unfortunately, I recently broke the power button on the same DS and had to open it up to remove the switch. I turned it back on, hit it a few times and Voila, it was working fine for about ten minutes. Now, my previously effective method is not working and I cannot find anything amiss inside the DS. Any suggestions?
P. S. Don't just say "buy a new one"
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
You should get the screen replaced
War diese Antwort hilfreich?
Bewertung 0
why is it black the screen
Bewertung 0
Antwort hinzufügen
Rowan Wiley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 529
