Zum Hauptinhalt wechseln
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
171 Fragen Alle anzeigen
Why won't my console turn on?
I had bought a preowned original xbox on Lukiegames and the system had worked fine for awhile but today it just suddenly refuses to turn on when I press either the tray button or power button. What is wrong with it and what do I have to do?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hi Sacatuki! Does the Xbox display any sort of indicator, such as a sequence of flashing leds on the power and eject button, or an error code on screen?
Try powering on the Xbox with a different power cable, on a different outlet in your home. This will rule out a faulty power cable and/or faulty power outlet. The Original Xbox uses a generic IEC cable - you most likely will have another device that uses the same cable, and if not they only cost around $4. If it still doesn't work after that, most likely your PSU has gone bad and needs to be replaced.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Ur idea is garbage, is not cable is xbox inside power supply.
von
Antwort hinzufügen
Sacatuki wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 3,252
