Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2686 Fragen Alle anzeigen
How to fix water damage
how to fix water damage
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
rscheeff, Remove battery ASAP, do not attempt to power on or charge the phone until after addressing the water issue. Use the links below to help repair your 6s from water damage, Link 1 is a tear down of your device and link 2 tells how to deal with water/corrosion inside the device. , Good luck.
iPhone 6s Teardown
Electronics Water Damage
War diese Antwort hilfreich?
Bewertung 2
– Turn the device off IMMEDIATELY & leave it off.
If there’s no power running through your circuit board, theres no power for the water to carry and send to the wrong places therefore it cannot do any damage. It is only that your phone is ON that the water causes damage.
– Don’t try to turn it on, leave it off till its been treated properly.
Remember if theres no power, theres no damage. The second you turn that phone on while there’s water inside it, your exposing it to risk of damage. There is every chance theres water sitting over the top of your CPU (basically the brain of the phone that controls almost everything). If you cause damage to that CPU chances are your data is gone forever. So don’t risk it! Leave it off until you can have the phone inspected and cleaned out properly.
– You need to have it treated within 3-4 hours if you want the best chance at fixing it before corrosion starts. Whenever you have copper, oxygen and water together, your going to get corrosion very quickly. The time before corrosion begins varies a lot between different liquids. Salt water can begin to cause corrosion inside your phone within about 20-30 minutes. Where-as tap water can take about 3-4 hours.
– Don’t try to charge it.
Again, if you charge it, your adding power to the phone which will only cause damage. NO GOOD CAN COME FROM CHARGING A WATER DAMAGED DEVICE.
– Do not dry the phone out, do not put it in rice, do not heat it up, do not put it in the sun. These are all stupid internet myths and do not do anything but speed up the corrosion process. As well as the fact that your not even putting the rice inside the device so its not going to do anything. Your charge port and head phone jacks are not hallow gateways into your phone.
Bewertung 0
Antwort hinzufügen
rscheeff wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 164
