Zum Hauptinhalt wechseln
Freihändig bedienbares, sprachgesteuertes Gerät von Amazon, betrieben durch den Alexa Voice Service. Modell S04WQR.
Alexa can't set alarm for me. Says is a problem when I ask.
In past could set alarm by asking Alexa to set alarm for a time specific. Now she says alarm set...then few seconds later say problem setting same. Help, thanks and Happy New Year.
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
I have 8 echo dots covering 3 generations...suddenly today only the first gen dot is able to understand what a timer is. The others reply with..."Hmmm, I'm not sure". Oddly, when I ask them how to set a timer they respond with, "say something like, Set a timer for 5 minutes", but when I do, I still get, "Hmmm, I didn't understand" or" I don't know that one".
von
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
I had the same issue. My Echo Dot was connected to wifi and would interact and tell me the temperature.
Every time I tried to set an alarm it would take the command, and then about 5 seconds later respond and say it had a problem setting the alarm.
After reading this post I decided to try power cycling it. That seems to have worked - it took the command. It also is showing up in my iPad Alexa app.
Problem solved.
War diese Antwort hilfreich?
Bewertung 3
There is a problem connecting to the amazon alexa service. You should check if it is connected to wifi, and if so, if the wifi is connected to the internet.
Bewertung 1
Sometimes Alexa enabled device like mobile app does not support alarms or timers.
Bewertung 0
Open the Alexa app. On the side menu, go to reminders and alarms, click the alarm tab and push the button to the on position
Bewertung 0
Just go to settings and choose factory reset option.
Follow the instructions and your problem will be solved…
Bewertung 0
Antwort hinzufügen
Larry Hirsch wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 24,999
