Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, mattschwarz oder hochglanz schwarz
1839 Fragen Alle anzeigen
Is there any way to fix these scratches?
Hello ifixit community! I am new to repairing and today I dropped my iphone and it slid across a concrete floor.
I was wondering if there is anyway to minimize the damage and to cover up some of the scuffs and scratches. I provided an image of the phone. Much appreciated!
http://imgur.com/a/rUIiP
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Kommentare:
So did u manage to remove the scratches or scuffs through polish?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@pars , Parsa, The same kits used to polish headlights could be used to get rid of a lot of the scars but probably not the deepest, the kits range from $20-$40 at auto parts and big box stores. You could also consider putting a wrap/skin on it which would clean it right up or perhaps put it in a case. Check the links below for covers/wraps/cases. 1st link is video showing how to wrap phone. Good luck.
https://www.youtube.com/watch?v=wjtSOpwh...
https://dbrand.com/shop/iphone-7-skins
https://www.slickwraps.com/devices/phone...
http://www.bestbuy.com/site/iphone-cases...
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
Thank you so much for the answer! Yeah I already ordered a skin for it, but just wanted to see if there is a way to remove at least some of the scratches if I decided to sell it someday.
von
Also would you mind leaving a link for the polish headlight you mentioned?
von
@pars , Your welcome, see links below polishing kit and 2nd link shows how to use it. Good luck with your device.
https://www.walmart.com/ip/3M-Headlight-...
https://www.youtube.com/watch?v=fvNSjjTH...
von
@pars So did u manage to remove the scratches or scuffs through polish?
von
oh yeah i can help you to clean and remove the light scratches on iPhone LCD and Bh01
von
The headlight solution that L Ptaff had suggested will potentially allow you to buff out the scratched plastic on your phone's narrow antenna lines. However the material on the flat back surface of your device is anodised aluminum. This is a silver metal with a very thin black top layer. Any heavy polishing is likely to strio the black color, revealing the lights bare metal underneath. However, at least if you try the pleasure polish alone, I doubt it would negatively ffect the anodised coat.
Bewertung 0
Antwort hinzufügen
Parsa Hasani wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 30
Letzten 30 Tage: 176
Insgesamt: 45,231
