Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Die Playstation 3 (im Volksmund auch PS3 genannt) ist das dritte Heimcomputer-Unterhaltungssystem der Firma Sony und der Nachfolger der PlayStation 2. Sie erschien am 11. November 2006
780 Fragen Alle anzeigen
My ps3 is hardly to power on!
hi all, i have a problem with my playstation 3 (2008 version - CECHL12)
It is very hardly to power it on, the most percent: when i press the power button, the green light is on and it say" beep " one time, but it cannot power on, my tv display "nosigal", and i cannot turn it off with power button. It just turn off when i push the button at its back.
if i press power button in long time ( about 5 seconds), it will power off with two beep.
some time, it works normaly. but when it powers on, i dont see any notece as " your ps3 was not turn off corectly ..." and my ps3 run normaly when ever i turn it off
the same issue if i use the ps button to power it on
how can i do to fix it? thanks for your help
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Give this a try: when you turn the PlayStation on, hold the power button until it turns on, and then keep holding the button for about 15 seconds. The console should beep a few times, and then restart. This will reset the video display settings, and auto detect the correct settings (digital vs analog).
Good luck, and let us know how it works out.
War diese Antwort hilfreich?
Bewertung 1
What cables are you using? Are you sure that your PS3 is set up to recognize it? If you are not using an HDMI cable, the system needs to be set to output using the composite cables. The TV cannot receive the signal if the PS3 is not outputting to the right port. Also, your english is extremely difficult to understand so I'm sorry I can't help you more than that.
Bewertung 0
Kommentare:
i'm sorry about my english.
I using Composite cable and a CRT TV
von
i think it have a problem with the power suply or logic board.
von
Antwort hinzufügen
peter pan wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 1,618
