Which components to turn a IBM x60 into a modern laptop?
The IBM X60, the first and best laptop I have had, has a 32-bits CPU (i686), 1.5 GB of RAM and a bit slow SATA I interface. It is a X60-1707.
I am looking for components so the upgrade will make it support:
- 64-bits processors
- 8 GB of RAM
- SATA III SSDs
Of course, I guess I will have to get through several difficulties :
- physical dimensions and constraints (ports, fans and screws location...)
- interface with existing hardware (LEDs, buttons,keyboard, USB ports...)
But I am only guessing since I have never done this before.
So I am asking the experts: which motherboard can fit in? May I have an Intel i3 ?
Thanks!
Ist dies eine gute Frage?
14 Kommentare
Get a program called cpu-z from the cpuid website. I am very familiar with Intel's CPU lineup, new and old. Open snipping tool, and give me screenshots of the chipset and CPU tabs, and any others you may think relevant. I am very willing to help, but doing this would help me much with my task.
von George A.
I actually just recently upgraded my old laptop's processor so it could run 64 bit programs too. The only real only two reasons you need a 64 bit OS is because it can support more than 3 GB of RAM, and a small amount of programs only work on 64 bit. 64 bit actually supports hundreds of GB of RAM, but the CPU or chipset can still limit it. However, a 32 bit OS will not affect a SSD or anything else.
von George A.
The processor is the only thing that limits 64 bit capability, but your laptop may not support any 64 bit processors, so that is what I will have you check. Replacement of the processor should be pretty easy. Once you give me the information I need, I'll give you my answer in full.
von George A.
Thank you @pccheese, but you're only answering the 64-bits part of the question. I also want to get through the 3 GB limitation of the chipset, and be able to benefit from faster SATA versions. So I edit both question and title to lower the 64-bits part.
von Tim
@pccheese: Since the chipstet prevent from supporting more than 3GB of RAM and only supports SATA I (see Upgrade of Lenovo t60 processor with a 64 bit processor), I will need to change the motherboard too.
von Tim
9 weitere Kommentare anzeigen
