Zum Hauptinhalt wechseln
Designed to provide professional results in a compact package, the J1 comes in a variety of colors and lens attachments.
Disabling Automatic Turn On Feature, Nikon 1 J1?
I have a Nikon 1 J1. I can no longer use it because of the automatic power-on feature.
Whenever any amount of pressure is put on the lens, the camera automatically turns on. This makes it impossible to carry around because the camera powers up any time you touch or bump the thing, and the battery is constantly dying on me. The only way of using it is to remove and replace the battery each time I want to take a picture -- which is obviously very impractical.
I wrote to Nikon once about this, and they told me that the camera was intentionally designed this way, and nothing can be done about it. Which is totally ridiculous.
Is there any way to DISABLE this automatic-on feature?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Did you find a solution? I have the same problem with a Nikon 1 V1
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I finally had to send the camera in to Nikon with a note explaining exactly what the problem was. I'm not sure what they did, but so far the problem has gone away. The auto-on feature is still there, but it's no longer so touchy.
They did not charge me.
von
Antwort hinzufügen
globetrodden wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 595
