Right USB Port doesn't work!
Hi folks,
I have another problem with my 15 inch MacBook Pro of 2015...
After replacing the screen twice, replacing the logicboard once due to technical problems and replacing the lower case including battery and keyboard due to a water damage, I can't use the right USB Port anymore.
Several external USB 3 HDDs and some USB Stick working sometimes. But mostly it doesn't work.
I reseted the PRAM, NVRAM and I made a Hardwaretest, without any problem signed.
Do you have any idea?
Greetings from Germany
Florian
Ist dies eine gute Frage?
3 Kommentare
Can you give me the board number? In that way I can give you the exactly component name to be replace it, it happen to me a couple times with different models, there is a driver filter that stop working and you have to replace it or the "USB driver" (is an IC) sometimes is in the same shape, sometimes work sometimes not, send the board number and I will send you the number and name of this IC.
von Juan Corredor
Where can I find this number?
von floriandanker
@juanccorredor Where can we find the board number?
von jago
