My Replacement Rear Panel doesn't have a Threaded hole.
The hole that holds the screw that holds the GPS antenna in. How can i go about this?
Ist dies eine gute Frage?
if you've the skills get out the drill or use a heated needle and make a starter hole which you can then push the screw into using a bit of pressure. It doesn't have to be screwed down. you could try a bit of doublesided tape-or that really sticky glue that can be reused (the type credit cards and stuff are stuck onto paper with when they get sent out?)
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 757
