Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1858 Fragen Alle anzeigen
iPhone 6s wont charge after screen replacement
i just replaced a friend's iphone 6s. Everything is working, but later she said the phone would no longer charge.
I told her to bring it back and i will take a look.
I checked the repair guide and nowhere did i touch the charging part.
Anyone seems this issue before?
Would the charging problem due to the phone drop that crack the screen?
thanks.
Ist dies eine gute Frage?
Punktzahl 0
Kommentare:
always unplugged the battery connector, following the repair guide.
von
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
3 Antworten
Hilfreichste Antwort
It is possible that the logic board did sustain some damage from the drop. If it was hard enough to crack the screen, then it could also do additional damage. The question is, was the phone properly charging the battery before the repair or not?
There could be damage to the charging circuit (Tristar) from the drop or it could be a coincidental problem with the the 6S battery.
There is a recall on that device...look here: https://www.apple.com/support/iphone6s-u... although Apple may not honour it due to a non-original screen. Check your serial number and worse case, re-install the original screen and have it checked by Apple.
War diese Antwort hilfreich?
Punktzahl 3
Did you disconnect the battery prior to performing the screen repair. On the 6s there is one pin on the top screen connector that stays charged with a significant voltage even when the phone is locked or turned off. If you did not disconnect the battery you may have caused some board damage. Usually this blows out the backlight IC but with stray voltage to ground you never know. I would take a close look at the battery connector on the board to see if it didn't short to ground.
Punktzahl 2
i got the phone and plug it in, it boots right up, but after it boot up, it did not show its charging.
so, it is detecting the the charger, cause it boot when its plug in.
I power down the phone and re-seat the lightning cable by the battery connector. also i clean out the lightning port, which has lints. then it starts to charge.
Punktzahl 0
Kommentare:
thats exactly my problem. I plug it in and the phone boots up. But no charging and no connection to Itunes. I have changed U2 already, but without luck. Any Ideas?
von
Did you reseat the lightning connector?
von
Antwort hinzufügen
ChiangFeng wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 31
Insgesamt: 874
