How could I fixs my phone battery becuase it dosent charge fully 3
my phone could turn on but when I go to charge it, it never charges fully and I was wondering if there is someway I could get it fixed
Ist dies eine gute Frage?
do you have to wiggle the charge port to get it to charge or just plug it in without wiggling?
War diese Antwort hilfreich?
I think we might need to know how old is the phone? About how many charge cycles has that battery been through? Also I would ask have you used a charger that was not what is recommended for that phone at all?
If the battery has a lot of charge cycles, it may be weak and not fully charge or hold a charge as long as it should. At which case you would need a new replacement.
Looking back, has the phone been plugged in to a outlet that might be questionable or a charger that might be bad? Those conditions can cause a battery to fail.
You can try to separate the battery cover and inspect the battery to see if it is swollen or shows other signs of damage. Though it sounds like a weak battery that needs replacement.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 164
