Zum Hauptinhalt wechseln
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26 Fragen Alle anzeigen
Just Rebooted Laptop keeps showing acer title in repeat doesnt startup
Rebooted my pc & it gets as far as acer title the screen turns black as if its loading then repeats the title... then you think somethings gonna load but it doesnt repeats acer title it wont start up... can this be fixed?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Need to know if you get beep codes ? If you get beep codes it's a hardware device if not it's usually a memory card or HD . Look up beep codes on web to check how many beeps mean what . A single beep is what you want . Also did you install new hardware if so take it out . Did you change anything ? Did you drop it . Need more info
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Gonzalez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 100
