Zum Hauptinhalt wechseln
Dritte Generation des Surface Pro Tablets ab 20.Juni 2014
123 Fragen Alle anzeigen
Hard Drive Connector or Adapter
I have a Surface Pro3 that was approximately destroyed. I managed to rescue the hard drive, but need to connect to it. Is there an adapter that will let me treat it like a regular SATA SSD?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
They do not use hard drive. They use solid state drives.
They use a mSATA interface. So you will need a mSATA to SATA adapter so you can plug it into a computer.
There might be a mSATA to USB adapter for convenience.
War diese Antwort hilfreich?
Bewertung 3
I believe what you are looking for is this:
https://www.amazon.com/Drive-Adapter-Con...
Bewertung 0
I believe what you are looking for is a Sata to usb Adapter which can be bought on Amazon.
Bewertung 0
Hi, Ben --
Thank you. I thought there would be an adapter, but I didn't know what it was called. I found mSATA adapters to both USB & SATA on Amazon.
I used the term "hard drive" as a generic -- old habit.
Thanks again,
Russ
Bewertung 0
Antwort hinzufügen
Russ Walden wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 3,874
