Zum Hauptinhalt wechseln
Das Galaxy S7 Edge ist die Variante mit gekrümmtem Bildschirm von Samsungs 2016 Flaggschiff-Smartphone, dem Galaxy S7. Angekündigt im Februar 2016 und am 11. März 2016 veröffentlicht. Modell SM-G935.
368 Fragen Alle anzeigen
Why phone overheats after repair?
i recently replaced the screen on my phone with a full replacement screen with frame and lcd assembly. The phone then worked fine for two hours and now it just says its overheating. no problems before the repair. but now phone is useless. any ideas???
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Where did you get the screen from? Did you check if the new screen replacement has the thermal pads installed on it just like the original screen had?
Also you maybe should of asked Samsung before for pricing as they may be cheapest for screen replacements.
von
Samsung won't fix it I called them first and yes it has the pads it was from a Samsung direct supplier
von
Had a customer come through after sending it in to Samsung for repair. It came back broke again! And refused to refund him!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Although painful, after you've just buttoned the phone, but you gotta. Check inside and see if anything is noticeably wrong or different. You may have damaged something during the repair
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
The heat comes from under one of the gaurds over the chips. I was very careful with the logic board. I made sure to use all precautions that i could.
von
Could be the display is drawing too much power. You may want to exchange it for an different one. I've seen that happen before
von
Antwort hinzufügen
cellrepair wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 24
Insgesamt: 2,953
