How do I bleed my radiator?
Where is the bleed valve for my radiator? 2000 model dodge dakota sport
Ist dies eine gute Frage?
@kushnpush , Peyton, The bleed port may only be on the 4,7 engine. See the 1st link below for bleeding procedure if not equipped with a bleeder use the second link. I would also continue to check the coolant level a few times over the next couple days and repeat procedure if you notice temp. gage acting strange or heater not producing heat as it would normally. Good luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 51
Insgesamt: 4,903
