Slow charging or Normal
My IPhone charges 0-100% in 4 hours
The current temperature is 4 degrees here
But when I make my iPhone a little hot it charges fast
Should I try once blow dryer to fix or what??
Ist dies eine gute Frage?
Shahid Akbar,
it's normal chemical reaction of the battery in -4C to 5 C. nothing to be worried about. :-) basic physics
War diese Antwort hilfreich?
Hi
- are you charging via computer or via wall socket?
- are you using the standard official charger that ships with the iPhone?
An Apple lithium-ion battery uses fast charging to quickly reach 80% of its capacity, then switches to slower trickle charging. So typically, a 0%-100% should take you around 3 hours, give or take.
Some tips to achieve faster charging:
- Use a wall socket
- Use an iPad charger (It's rated at higher amperage)
- Switch on Airplane mode while charging (charging time cuts down to almost half!)
Hope it Works
Thanks
Varun
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 146
sir dont do any heating you proper charger .... or change your lighting connector and adaptor
von vinod
