Zum Hauptinhalt wechseln
Die 2013er Neuauflage des Mac Desktops, bekannt als Mac Pro.
117 Fragen Alle anzeigen
Mac Pro (2013) CPU & Riser card bus bar screws torque value
The Mac Pro (2013) CPU riser card bus bar screws need to be tightened to a torque value. Does anyone know what it is?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Are you referring to the 4x bus bars that attach and ground the CPU to the PSU? if so, it is the following:
Bus Bar to PSU Screws
Use the torque driver with the T8 security bit to install the four (4) T8 bus bar screws (923-0712) to 7.5 inch pounds (in.-lbs.) or 0.85 Newton metres (Nm).
Bus Bar to CPU Riser Screws
Using torque driver with T8 security bit, install two T8 bus bar screws (923-0716). Tighten bus bar screws to torque value of 10.5 inch pounds (in.-lbs.) or 1.2 Newton metres (Nm).
If you are referring to the CPU heatsink and locking bar, its as follows:
Using torque driver with a regular T10 bit, install four T10 screws (923-0707) in sequence shown until all screws are tightened to 10.5 inch pounds (in.-lbs.) or 1.2 Newton metres (Nm).
I hope this helps.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
zaheer khan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 595
