Zum Hauptinhalt wechseln
Repair guides and support for Kurio tablets.
69 Fragen Alle anzeigen
Why is my sound not working?
I have video but no sounds
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Laurin Mckenzie, Below is a link #1, which you can select your devices guide from which will show how to open device to see if speaker wire is loose or enable you to replace speaker if need be, you can also hook a small speaker up temporarily to test if on board speaker is bad. You should also inspect the ear phone jack port for dust/debri which could be keeping contacts in side connected. If you notice something in port try sucking out with vacuum or picking out with a tooth pick, then slide the the ear phones jack pin in and and out a few times. The second link has info. which may also help. Good luck.
Kurio Tablet Repair Guides
tablet speakers do not work anymore; only with headphones
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Laurin Mckenzie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 327
