Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
20 Fragen Alle anzeigen
Lid does not remain closed all the way but pops back up
I am having a problem with my lid not remaining closed when not in use. As I attempt to close the lid it springs back up about a quarter of an inch. There are no dents in the case and nothing on the exterior that looks suspect. It seems as though the magnets do not engage preventing it from closing all the way. Has anyone experienced this problem? Is there a fix to realign the magnets? Please help. Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Could be a few things;
1. If the screen has not been replaced previously, remove the bottom cover and rubber hinge covers, and loosen all 6 hinge screws. Align the lid slightly and tighten the screws, see if it has the same issue. Loosening the screws slightly and leaving them like this can also resolve the problem. Usually caused by bend in aluminium by the hinge cover.
2. If screen has been replaced, it is possible they have sold you one with no magnet inside the lid (has happened to me before)
3. If it is a new screen and not original, there is possibly a bump in the rubber bezel, which causes it to not close properly. Feel the bezel around the screen to check this
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Also the hinge clutch can also bind up a bit, which will require replacing the hinges.
von
Hi Reece and Dan,
Thank you both for your suggestions. Loosening the hinge screws and slightly realigning the lid worked for me. I really appreciate it.
von
Antwort hinzufügen
Bernie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 13,067
