Zum Hauptinhalt wechseln
The Asus VivoBook Pro N552VW has an i7-6700HQ processor, 16GB DDR4 RAM, NVIDIA® GeForce® GTX 960M and 2G/4G GDDR5 VRAM. Released in 2016.
MyAsus application ( Asus n552vw / Windows 10 / 64 bit ) doesn't open
myAsus App in ( Windows 10 version 1511 ) worked perfecty fine until i was forced to update to the anniversary version 1607. After the update the application opens up showing the logo of it for a few seconds and then shuts down. Version of the app was also automatically updated to 3.2.1.0, unfortunately i don't recall which version i had before.
Is there any way to fix this in order the application to work properly again in the latest version of Windows 10?
I have also tried uninstalling the app and trying to reinstalling it, which resulted in not being able to install it at all...
I don't know if this helps but the ATK package installed is 1.0.0040.
Thank you in advance,
Sofia
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
8 Kommentare
Hi, Is this where you got the app from to re install?
https://www.microsoft.com/en-sg/store/p/...
von
Hello and thank you for replying! Yes exactly because i couldn't install it either from the Greek microsoft store. Any suggestions?
von
Hi @sofpa ,
I notice by the comment at the bottom of the link I sent that you are not the only one having a problem.
What actually happens when you try to install it? (I can't try it because I don't have Win 10 (it doesn't like Vista - yes its' old like me). What error message(s), if any, do you get?
Is it an .exe file, .msi or similar that you download and then have to install?
Have you tried right click on the file and select 'Run as Administrator' when you go to install it?
von
Hello Jayeff,
Apparently there is at the very least another unfortunate one out there in the digital world who is encountering possibly the same exact problem with me.
In Windows 10 ( Windows 8 & 8.1 also - not familiar with Vista, but huge fan of Windows 7, still missing them ) as far as it concerns applications, you can download them directly by using the Microsoft store app. The MyAsus App comes preinstalled with the laptop model Win 10 version 1511, but after the update i couldn't find it in the store so i tried using the web and discovering the same link that you posted before i have clicked the option Get the app the installation begins but it stops abruptly with an error message indicating 0x800.
If it was an executable tangible and playable file i am guessing it would be much more easier for me to find a solution...
von
Hi,
Have you ensured that your Win 10 installation is up to date (I realize that it should be but....) by going to Settings > Update and Security > Windows Update and manually checking that it is up to date?
If it is then perhaps the problem is with the app and not you. If you really want it contact Asus and ask them why it doesn't work with Win 10 1607
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
I would like to notify that i have contancted Asus Support Customer Service about the issue i was encountering with the MyAsus App in Windows 10 anniversary edition 1607. They informed me that they have forwarded my case to the responsible department and requested a new utility version to be released in order to fix this.
So what remains is to wait for a newer version of the application to solve the compatibility issue with the latest version of Windows 10.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Sofia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 13,472
